Tuga86 Posted August 11, 2015 Share Posted August 11, 2015 Hi My Zed sometimes doesn't accelerates as it should, looks like it looses power, cleaned the throttle body and I noticed it was better at the beginning but was not for long, put the computer on it but have no faults so I'm thinking of buying one, looking for advice, do you guys think I should buy it or should do something else? Any suggestions r welcome Cheers Enviado do meu SM-G925F através de Tapatalk Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 11, 2015 Share Posted August 11, 2015 Have you cleaned the MAF, checked for air intake leaks and checked the filter/s? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 11, 2015 Share Posted August 11, 2015 (edited) Fully working pre owned TBs are in stock and good to go same/next day if required. Just drop me a PM if I can help you further. Alex. Edited August 11, 2015 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
Tuga86 Posted August 11, 2015 Author Share Posted August 11, 2015 Have you cleaned the MAF, checked for air intake leaks and checked the filter/s? Yes I checked, I think not any of those but I'm not completely sure it is the throttle body. Enviado do meu SM-G925F através de Tapatalk Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 11, 2015 Share Posted August 11, 2015 The throttle body is unlikely to cause any power loss, unless its not calibrated to the pedal box, try a reset/recalibration and see if that helps. 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 11, 2015 Share Posted August 11, 2015 PMs received and replied to. Quote Link to comment Share on other sites More sharing options...
Tuga86 Posted August 12, 2015 Author Share Posted August 12, 2015 The throttle body is unlikely to cause any power loss, unless its not calibrated to the pedal box, try a reset/recalibration and see if that helps. I'll try that too. Cheers Enviado do meu SM-G925F através de Tapatalk Quote Link to comment Share on other sites More sharing options...
