Kaveney Posted August 11, 2015 Share Posted August 11, 2015 I have had a look but could not fine an answer for this one . On the std 18" Rays with MPSS all round what PSI are people finding best . 35 PSI is std but I have read with the MPSS 32/33 PSI is best ? Thanks Alan Quote Link to comment Share on other sites More sharing options...
Dynamic Turtle Posted August 11, 2015 Share Posted August 11, 2015 35 PSI unless you're doing heavy track work in which case you might want to drop it to 30-32 to account for all the flaming powerslides you'll be doing around Castle Coomb... Quote Link to comment Share on other sites More sharing options...
KyleR Posted August 11, 2015 Share Posted August 11, 2015 35 is fine. If you find you're not comfortable with that after trying it out, let a couple of PSI out and try again. 35 really isn't that much, so I'm sure it'll be fine. 1 Quote Link to comment Share on other sites More sharing options...
Kaveney Posted August 11, 2015 Author Share Posted August 11, 2015 Ok many thanks Alan Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 11, 2015 Share Posted August 11, 2015 32/33 would be my preference. Starting with 35/35 and adjusting to suit is also a perfectly acceptable start. Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted August 11, 2015 Share Posted August 11, 2015 35psi if tyres are warm. 32psi if they are cold. Cold means not driven (normally) for more than two miles to get to a suitable air pump if you had to travel to get to one. I also use 29psi cold or 32psi hot when driving it hard. Quote Link to comment Share on other sites More sharing options...
