Project: WeaponiZed
V1H
Yesterday was great sunny day and I installed the handbrake.
The centre console trim needs to come off and you get access to the handbrake. Remove the three M12 bolts, one M10 nut holding the Bowden cable and disconnect the connector.
Here the OEM vs new carbon/burnt titanium piece:
Because the handle is now thicker, I found it best to first remove the rubber lining the opening on the console:
Now the new handbrake would just fit through the opening when putting the centre console back in place. The rubber lining can be slid back and push into place at the end
Edited by V1H
