MG Mark Posted August 7, 2015 Share Posted August 7, 2015 Just joined the forum and have searched for advice on clutch replacements, but can't find quite what I'm after. My clutch slave cylinder failed quite comprehensively today on the way back from work, resulting in the ignominy of recovery on the back of an AA truck, back to my local chap who has worked on the car since buying it nearly a year ago. Car is a 2007 VQ35HR, so the problem comes with that added bonus of needing to drop the gearbox because of the concentric slave cylinder...... The master cylinder was replaced about 3 months ago when that failed, so I suppose the slave going was only a matter of time. Car has covered 58k miles and, otherwise, no problems with the clutch or gearchanges - nice and smooth, progressive, no slipping or juddering, biting point just over halfway down the pedal travel. Normal mixed driving on A and B roads and motorways, spirited driving, but not ragging it. So to the question - as the clutch and flywheel seem good, how worthwhile is it changing them at the same time? And, I've seen the posts about SMF v DMF - best to stick with DMF for the cushioning of loads? Any instances of SMFs inducing undue loads on the engine's crank? Thanks Mark Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 7, 2015 Share Posted August 7, 2015 100%, that's a no-brainer on a HR. And always go SMF as well, there's been no failures of the kind you mention that I'm aware of, and the performance benefits alone are worth it. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 7, 2015 Share Posted August 7, 2015 At 58K then you will probably require a clutch change and perhaps a fly, however your technician will advise once he drops the box and inspects. Best also to upgrade the CSC. Quote Link to comment Share on other sites More sharing options...
MG Mark Posted August 7, 2015 Author Share Posted August 7, 2015 (edited) That was the question I also meant to ask - having seen the posts on their failure too - i.e there an upgraded CSC......as you mention one, what has been upgraded and where can I get one? Thanks, Mark Edited August 7, 2015 by MG Mark Quote Link to comment Share on other sites More sharing options...
