monkeybrain1234 Posted August 6, 2015 Share Posted August 6, 2015 Was not convinced it made any real difference to the naked eye, but when I looked at before and after pictures there sure is a difference. These pictures are with no waxes applied just the PoorBoys Black Hole, rubbish iphone pics but does show the difference. Before - Only Washed After - Poorboys Black Hole applied by hand only, (no wax on it). Quite impressed with the result. 1 Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 6, 2015 Share Posted August 6, 2015 Yes, good stuff of darker shades of cars and easy to use now I have let myself in for polishing the neighbours cars well 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 6, 2015 Share Posted August 6, 2015 I've found it doesn't last that long though still a great product for a bit hiding some light swirls . Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 6, 2015 Share Posted August 6, 2015 That's because it's a glaze not an LSP; it needs to be topped with either a wax or sealant. 1 Quote Link to comment Share on other sites More sharing options...
Chris Wiltshire Posted August 6, 2015 Share Posted August 6, 2015 Looks good, I started using this recently and it does give a deeper gloss finish to my car but doesn't seem to hide much even light swirls. It's a nightmare if you have a lot of tiny stone chips in the front bumper as it fills them and then dries white leaving the chips noticeable. I couldn't even buff it out , 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 6, 2015 Share Posted August 6, 2015 That's because it's a glaze not an LSP; it needs to be topped with either a wax or sealant. Yes I put britmax wax ( 2 layers) over it but still the light swirls came back pretty quick Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 6, 2015 Share Posted August 6, 2015 Sorry, I misunderstood your post. If the LSP over it is good, it should last 3-4 weeks quite comfortably. It could be that the Britemax wax hasn't bonded well to it and it's washed off or it be newly inflicted swirls - I'm assuming you've used that combo on the Z? The Z's paint is very easy to marr with it being so horrendously soft. Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 6, 2015 Share Posted August 6, 2015 Sorry, I misunderstood your post. If the LSP over it is good, it should last 3-4 weeks quite comfortably. It could be that the Britemax wax hasn't bonded well to it and it's washed off or it be newly inflicted swirls - I'm assuming you've used that combo on the Z? The Z's paint is very easy to marr with it being so horrendously soft. Ya it's crazy soft ...... I use snow foam , 2 bucket every wash and still think I'm adding more light swirls every time Might try some pure water for the final rinse down so I don't need to dry it and hope this can slow the swirling a little ! Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 6, 2015 Share Posted August 6, 2015 I'm pretty sure mine gets marred every time I just look at it. 3 Quote Link to comment Share on other sites More sharing options...
sipar69 Posted August 6, 2015 Share Posted August 6, 2015 Yes, good stuff of darker shades of cars and easy to use now I have let myself in for polishing the neighbours cars well The version for white cars works well too. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 6, 2015 Share Posted August 6, 2015 Black Hole works well on white (or any light colours) too, by the way. Also, White Diamond works equally well on dark colours. 1 Quote Link to comment Share on other sites More sharing options...
monkeybrain1234 Posted August 6, 2015 Author Share Posted August 6, 2015 Yes, good stuff of darker shades of cars and easy to use now I have let myself in for polishing the neighbours cars well It was simple to use which I like, I would not trust myself with a DA polisher! You are a nice neighbour doing there car Colin. Hope the AMG is going well I've found it doesn't last that long though still a great product for a bit hiding some light swirls . Not sure how long it will last, but will wax it over and see what happens. As they say, time will tell! Looks good, I started using this recently and it does give a deeper gloss finish to my car but doesn't seem to hide much even light swirls. It's a nightmare if you have a lot of tiny stone chips in the front bumper as it fills them and then dries white leaving the chips noticeable. I couldn't even buff it out , I agree with this, didnt seem to cover much up in terms of swirls I found too, just seems to give it a more glossy/mirror finish. Maybe I didnt apply it too well. With the stone chip problem and filling it in white, I had this issue previously with waxes, I just used an old toothbrush to gently brush the wax from the stone chip, generally worked quite well. Could be worth a try. . . . Quote Link to comment Share on other sites More sharing options...
sipar69 Posted August 6, 2015 Share Posted August 6, 2015 Black Hole works well on white (or any light colours) too, by the way. Also, White Diamond works equally well on dark colours. Yup. It's all in the marketing Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 6, 2015 Share Posted August 6, 2015 (edited) Following on from this thread .... I finished early today so done a front end correction , using megs compound ( can't remember which one ) followed by britmax ultimate finisher , followed by black hole , and 2 coats of britmax vintage . Pleased with the results ...... Just the rest of the car to do now!! Edited August 6, 2015 by Bodyboarder81 6 Quote Link to comment Share on other sites More sharing options...
The G Man Posted August 6, 2015 Share Posted August 6, 2015 ^^^ that Z looks pleased with itself 1 Quote Link to comment Share on other sites More sharing options...
Shenley Posted August 6, 2015 Share Posted August 6, 2015 Saw this thread and thought Stephen Hawking had joined the forum....... However as I'm changing car (to red) I have had to forgo my blue velvet and invest in some banana armour. 1 Quote Link to comment Share on other sites More sharing options...
Deano94 Posted August 6, 2015 Share Posted August 6, 2015 looks great. Do you ever get stopped with your plate like that? Front end looks so much better. Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 6, 2015 Share Posted August 6, 2015 looks great. Do you ever get stopped with your plate like that? Front end looks so much better. I haven't yet ....... But bear in mind I only do about 2-300 miles a month . I've really got to put it back on , not worth the £100 and 3 points ..... Sad really as it looks so smooth without it Quote Link to comment Share on other sites More sharing options...
Deano94 Posted August 6, 2015 Share Posted August 6, 2015 Yeah shame. Didn't realise it was 3 points too, not worth the risk. Quote Link to comment Share on other sites More sharing options...
monkeybrain1234 Posted August 7, 2015 Author Share Posted August 7, 2015 Following on from this thread .... I finished early today so done a front end correction , using megs compound ( can't remember which one ) followed by britmax ultimate finisher , followed by black hole , and 2 coats of britmax vintage . Pleased with the results ...... Just the rest of the car to do now!! Now that's called a good finish. Like a smoked mirror. Well done. 2 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 7, 2015 Share Posted August 7, 2015 And yet this morning you can still see lots of fine swirls !!! All depends on the light really . 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted August 8, 2015 Share Posted August 8, 2015 That's why the cars in the US look great on the front end, they don't have to bear that ugly plate. Quote Link to comment Share on other sites More sharing options...
THUNDERZED Posted August 29, 2015 Share Posted August 29, 2015 Following on from this thread .... I finished early today so done a front end correction , using megs compound ( can't remember which one ) followed by britmax ultimate finisher , followed by black hole , and 2 coats of britmax vintage . Pleased with the results ...... Just the rest of the car to do now!! What lip is this, it seems to follow the original bumper design of the facelift bumper keeping the cut in below the grille? very nice!! 1 Quote Link to comment Share on other sites More sharing options...
chirag1988 Posted August 29, 2015 Share Posted August 29, 2015 Following on from this thread .... I finished early today so done a front end correction , using megs compound ( can't remember which one ) followed by britmax ultimate finisher , followed by black hole , and 2 coats of britmax vintage . Pleased with the results ...... Just the rest of the car to do now!! What lip is this, it seems to follow the original bumper design of the facelift bumper keeping the cut in below the grille? very nice!! Mines lip I believe. I have the same on mine and love it Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 29, 2015 Share Posted August 29, 2015 It's the stillen front lip ..... Painted to match the car . It's made from solid plastic/ hard rubber so doesn't crack and chip like fibreglass ones . I've beaten it a few times on the underside and thank stillen for their build quality !! Quote Link to comment Share on other sites More sharing options...
