HMB 350z Posted August 4, 2015 Share Posted August 4, 2015 Hi guys I need your help, I need a new clutch for my 350z and wanted advise on how much I should be paying for the kit??... I've come across these and wanted to know if the brand was any good? Thank! Quote Link to comment Share on other sites More sharing options...
Will370z Posted August 4, 2015 Share Posted August 4, 2015 Moved topic, good luck with the clutch Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted August 4, 2015 Share Posted August 4, 2015 (edited) First of all welcome to the forum. I see that you are in Coventry if I was you I'd get in touch with Mitz@cougarstore a zed specialist and trader on here who is based in Leicester who will give you your options. http://www.cougarstore.co.uk/ http://cougarstore.co.uk/index.php?main_page=index&cPath=1_14 Edited August 4, 2015 by SHEZZA Quote Link to comment Share on other sites More sharing options...
Humpy Posted August 4, 2015 Share Posted August 4, 2015 Also if you are doing the clutch you might aswell do the flywheel. Might make it a little more costly to begin with but cheaper in the long run Quote Link to comment Share on other sites More sharing options...
Durk Posted August 4, 2015 Share Posted August 4, 2015 Good to see another member from Coventry! I second what Shezza said about Cougar Store too.. Quote Link to comment Share on other sites More sharing options...
HMB 350z Posted August 4, 2015 Author Share Posted August 4, 2015 Cheers guys! Quote Link to comment Share on other sites More sharing options...
alexfergs Posted August 6, 2015 Share Posted August 6, 2015 Hi guys I need your help, I need a new clutch for my 350z and wanted advise on how much I should be paying for the kit??... I've come across these and wanted to know if the brand was any good? Thank! How did you know you need a new clutch? I'm a bit worried that mine is on the way out, what are the symptoms (Stock clutch) Quote Link to comment Share on other sites More sharing options...
35oz's Posted August 6, 2015 Share Posted August 6, 2015 Mine started to slip when pulling away or changing gear, you could hear the revs increase as the clutch would slip Quote Link to comment Share on other sites More sharing options...
DarmoZ Posted August 6, 2015 Share Posted August 6, 2015 Cougar store or Adrian from torqen (trader on here) will get you the parts, will need clutch and flywheel combo. Then just find any garage with reasonable labour rate to do the job Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
GriffGTV Posted August 6, 2015 Share Posted August 6, 2015 ..time to consider lightened fly & uprated clutch? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted August 6, 2015 Share Posted August 6, 2015 This is a very popular option with members on here with a lot of happy customers http://www.350z-uk.com/topic/95545-new-xtreme-clutch-organic-inc-smf-350z-de/ Please get in touch if you need any advice we can guide you through the various options Quote Link to comment Share on other sites More sharing options...
