MPv6 Posted August 3, 2015 Share Posted August 3, 2015 Like the topic says, is this sound normal or is it something that needs to be changed? It's just been emptied on oil here, refilling later this week. http://www.markusp.s...ad/IMG_7056.mp4 Quote Link to comment Share on other sites More sharing options...
Vlad Posted August 3, 2015 Share Posted August 3, 2015 Sounds normal to me mate. Any play in the shaft? If not - it should be fine. They are noisy superchargers. Quote Link to comment Share on other sites More sharing options...
MPv6 Posted August 3, 2015 Author Share Posted August 3, 2015 On 03/08/2015 at 13:55, Vlad said: Sounds normal to me mate. Any play in the shaft? If not - it should be fine. They are noisy superchargers. Ok, thanks! No, not that I can see when I spin it by hand. Quote Link to comment Share on other sites More sharing options...
Vlad Posted August 3, 2015 Share Posted August 3, 2015 Try spinning it back and forward and see if you got clunking noise. You can try to move impeller shaft by hand...if it's solid - then you ok Quote Link to comment Share on other sites More sharing options...
MPv6 Posted August 3, 2015 Author Share Posted August 3, 2015 On 03/08/2015 at 14:22, Vlad said: Try spinning it back and forward and see if you got clunking noise. You can try to move impeller shaft by hand...if it's solid - then you ok I will try that, thank you! Hopefully it's all solid. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted August 3, 2015 Share Posted August 3, 2015 I agree with vlad, just sounds like a supercharger without oil, the oil also acts as a dampner when operational. Quote Link to comment Share on other sites More sharing options...
