eatonm90 Posted August 2, 2015 Share Posted August 2, 2015 Just done all the timing chains, guides and tensioners my Zed. Currently on 98,717 miles and start up noise was getting pretty bad, took the cover plate off and the tensioner was out 19.5 mm. I had already started to get the parts together and did the job over a few days. What a time consuming PITA job, ever since I was a lad I have been into Mini's so quite used to tight spaces but this job with the engine in really pushed the limit at times. Parts replaced: Main chain Cam chains All guides All 3 tensioners Water pump Crank sprocket Pulley seal L/H cam cover (due to leaking plug seal on No.6) Parts used Before replacement Tensioner travel Damage to main guide The tensioner was so far out that the chain had started to hit the main casing and I guess was jumping about on start up on the guide causing the damage, the chain hitting the casing was probably the noise I could hear. Glad I got a new crank sprocket as well, the wear was pretty bad. I got this Payen seal set which had all the seals and o rings needed for the job, lower crank half moon seal was slightly too thick on the curved sections where they turn onto the upper sump so needed to sand the ends down a bit, found this out after 3 attempts to fit, now so good at applying silicone might re do my bathroom. All fitted, timing marks on chains don't show lined up in the image because I have done a few engine turns. Note tensioner travel, 10mm. I can see why the labour costs are so high for the job but it is do able if you take your time, the result is absolutely silent start up from cold. I wanted really to do a step by step but there is loads of info on the net, so glad I did this and now all the parts are the latest Nissan updates, cost is still high though even without paying labour. 14 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 2, 2015 Share Posted August 2, 2015 Good effort: 1 Quote Link to comment Share on other sites More sharing options...
MIGWEL Posted August 2, 2015 Share Posted August 2, 2015 Brilliant job done and really satisfying for you too now you have a silent engine .. Good for you 1 Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 2, 2015 Share Posted August 2, 2015 Good info there - pinned this given more and more owners will be in a similar position sooner or later 1 Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 2, 2015 Share Posted August 2, 2015 Top job buddy, how much did the parts amount to? Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted August 2, 2015 Share Posted August 2, 2015 Good effort mate and yes as glrnet said roughly what price for the parts Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted August 2, 2015 Author Share Posted August 2, 2015 the whole lot excluding the cam cover was a shade over £600. I could probably have got away with out the water pump £80, the two cam chains £180 and the tensioners to match £150 but the tensioners had signs of wear and I have fitted the latest part numbers. The car is my daily so had to make sure I had it all ready and kind of made sense to do it all once and not strip it again.. 4 Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted August 2, 2015 Share Posted August 2, 2015 Not a bad price for all that mate Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted September 1, 2015 Share Posted September 1, 2015 Hi, doing ours in a couple of weeks. Can I ask did you take the front panel, bumper and crash bar off to do the work, or just take the radiator and fans out? Thanks Andy Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 1, 2015 Share Posted September 1, 2015 Hi, doing ours in a couple of weeks. Can I ask did you take the front panel, bumper and crash bar off to do the work, or just take the radiator and fans out? Thanks Andy Don't know what procedure the OP followed, but best to remove bumper and front panel etc. Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted September 1, 2015 Author Share Posted September 1, 2015 andyk3090, on 01 September 2015 - 19:47, said: Hi, doing ours in a couple of weeks. Can I ask did you take the front panel, bumper and crash bar off to do the work, or just take the radiator and fans out? Thanks Andy Don't know what procedure the OP followed, but best to remove bumper and front panel etc. No, left the bumper and front panel on but yes it probably would have been easier removing them. Quote Link to comment Share on other sites More sharing options...
gsexr Posted September 1, 2015 Share Posted September 1, 2015 Great effort mate and a job well done. You must be chuffed Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted September 2, 2015 Share Posted September 2, 2015 andyk3090, on 01 September 2015 - 19:47, said: Hi, doing ours in a couple of weeks. Can I ask did you take the front panel, bumper and crash bar off to do the work, or just take the radiator and fans out? Thanks Andy Don't know what procedure the OP followed, but best to remove bumper and front panel etc. No, left the bumper and front panel on but yes it probably would have been easier removing them. Thanks for the advice guys, hopefully all will go smoothly once I have all the parts (and they don't go missing in transit again)... Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted September 2, 2015 Author Share Posted September 2, 2015 andyk3090, on 01 September 2015 - 19:47, said: Hi, doing ours in a couple of weeks. Can I ask did you take the front panel, bumper and crash bar off to do the work, or just take the radiator and fans out? Thanks Andy Don't know what procedure the OP followed, but best to remove bumper and front panel etc. No, left the bumper and front panel on but yes it probably would have been easier removing them. Thanks for the advice guys, hopefully all will go smoothly once I have all the parts (and they don't go missing in transit again)... Good luck, take your time with the silicone and fitting the front cover to make sure the lower crank seal seats correctly. Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted September 3, 2015 Share Posted September 3, 2015 andyk3090, on 01 September 2015 - 19:47, said: Hi, doing ours in a couple of weeks. Can I ask did you take the front panel, bumper and crash bar off to do the work, or just take the radiator and fans out? Thanks Andy Don't know what procedure the OP followed, but best to remove bumper and front panel etc. No, left the bumper and front panel on but yes it probably would have been easier removing them. Thanks for the advice guys, hopefully all will go smoothly once I have all the parts (and they don't go missing in transit again)... Good luck, take your time with the silicone and fitting the front cover to make sure the lower crank seal seats correctly. Many thanks for the advice, it is much appreciated, I agree more haste, less speed... Quote Link to comment Share on other sites More sharing options...
tonman83 Posted May 19, 2016 Share Posted May 19, 2016 Great effort, big hand on that. Quote Link to comment Share on other sites More sharing options...
veilside z Posted May 21, 2016 Share Posted May 21, 2016 Fair play to take that on buddy. Well done Quote Link to comment Share on other sites More sharing options...
NazMan Posted May 21, 2016 Share Posted May 21, 2016 Great work mate, and you have the added reassurance of knowing you used nice genuine OEM Nissan parts throughout. Did you source them online or at your local Nissan dealership? Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted May 21, 2016 Author Share Posted May 21, 2016 Great work mate, and you have the added reassurance of knowing you used nice genuine OEM Nissan parts throughout. Did you source them online or at your local Nissan dealership? Some local Nissan but most from USA, main chain was £100 cheaper inc duty etc than UK source. Quote Link to comment Share on other sites More sharing options...
NazMan Posted May 21, 2016 Share Posted May 21, 2016 Thanks for the reply; can you please post a link for the US Nissan parts supplier? Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted May 22, 2016 Author Share Posted May 22, 2016 https://conceptzperformance.com/ https://www.z1motorsports.com/ Either of the above are good do deal with, both are well known US suppliers. Quote Link to comment Share on other sites More sharing options...
Watola123 Posted June 16, 2017 Share Posted June 16, 2017 Fair play to you, thanks for the great pics and post Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted June 16, 2017 Share Posted June 16, 2017 I'm in the process of doing mine but on a complete rebuild. Can I ask where you got the oring set? I've been struggling trying to individually source each 1 Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted June 16, 2017 Author Share Posted June 16, 2017 Yep, got it off Amazon, only place I could find it after a long search. Link below. https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=eg8230 Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted June 19, 2017 Share Posted June 19, 2017 Yep, got it off Amazon, only place I could find it after a long search. Link below. https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=eg8230 Ahhh only just seen your reply. I've just spent 140 for it from z1 motorsport but it comes with all the gaskets aswell so I suppose it's not too bad :/ Quote Link to comment Share on other sites More sharing options...
