1st Time Wiring in Head Unit - JVC
So its my first time changing a head unit. I enjoy a challenge so thought I would give it a go based on some advice and videos! :scare:
Fed up of the skipping 6 CD Changer :rant: so got a simple DAB JVC unit KW-DB60AT
Got all the connections and facsia thanks to Buster for the links
Old Bits that came with the unit from the guy I bought it from (Not sure if any of the bits will be useful, no idea what car it came out of)
New bits - Loom, Steering Wheel control & Facsia
Think thats all I need. Right? Its a Non Bose system so Hopefully its fairly simple! :lol:
Never taken any trim off before so using this video for reference . . . .
Going to do this on Saturday - wish the first timer good luck and any tips you have would be great. :teeth:
make sure your earth's are good otherwise you'll end up with whizzing and suppression noises. Not nice. lol Good Luck
Thanks for advice - When you say "good" what would you deem a "good" earth? :wacko:
Just connected securely to the chassis, I found a nice big bolt just behind the gear shift and never had any issues with alternator whine or hissing :thumbs:
Will look out for that one. :thumbs: :thumbs:
Looking forward to seeing it fitted. I wonder if the 370 stereos will follow the same traits as the old 350. :wacko:
More than likely :crutches:
Just getting fed up with the skipping and I had a DAB in last car which was rather good. Not to mention the old school look with a tape deck!! :scare:
Okay need help - All works fine, put it all back together. But I have just gone back to the car and the memory has gone. All the stations/presets etc
Done some searching on web, seems there are two lives (Ignition on live and Constant live)! Everything else works fine. Any ideas which wires I need to change? :surrender:
red and yellow.
Buster to the rescue . . . :yahoo:
So what should I do? Swap the yellow and red around??????
Found this online as cannot find any wiring diagrams in my Z manual :wacko:
Radio Constant 12V+ Wire: Yellow
Radio Switched 12V+ Wire: Light Green
Radio Ground Wire: Chassis
Radio Illumination Dimmer Wire: Red/Blue
Radio Antenna Trigger Wire: Green/White
Radio Amplifier Turn On Wire: Green/Yellow
Left Front Speaker Wireicon1.png (+): Blue/Red
Left Front Speaker Wire (-): Black/White
Right Front Speaker Wire (+): Yellow/Red
Right Front Speaker Wire (-): Red/White
Left Rear Speaker Wire (+): Light Green/Red
Left Rear Speaker Wire (-): Black/Yellow
Right Rear Speaker Wire (+): Blue/Orange
Right Rear Speaker Wire (-): Black/Pink
All done. :yahoo: I found that the Red and Yellow had been cut and switched previously, was easy to rectify as was done with Male / Female connector. Simple resolution.
Thanks for everyones help, particularly Buster. :teeth:
Finished & Installed. DAB, Non Skipping CD, USB and cool light colours!
