terry06 Posted July 27, 2015 Share Posted July 27, 2015 I have bought TRIX iron and tar remover to use before claying my car for the first time and assumed it will be ok to use on wheels and bodywork but a friend has warned me against using it on the body. With the zeds fragile paint I thought I would get clarification from you guys before using it. Will it be ok on the body? (Especially areas with stone chips) Anything else I should be aware of when using it? I am prepared for the smell Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 27, 2015 Share Posted July 27, 2015 It's designed for use on the body, it'll be fine As always though, avoid letting it dry or applying in direct sunlight to hot panels. 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted July 27, 2015 Share Posted July 27, 2015 It's fine on the bodywork. Tar remover isn't particularly good for black plastic trim though, so go careful around the relevant areas and don't let it dry on anything. Other than that you don't really need to take any special care. 1 Quote Link to comment Share on other sites More sharing options...
terry06 Posted July 27, 2015 Author Share Posted July 27, 2015 Thanks guys I thought that would be the case but didn't want to go and ruin the paint if I was wrong Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 27, 2015 Share Posted July 27, 2015 I used TRIX. Was hoping for more from it Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted July 27, 2015 Share Posted July 27, 2015 Trix isn't anywhere near as good as two dedicated products, but none of the combined tar & fallout removers are to be honest. 1 Quote Link to comment Share on other sites More sharing options...
terry06 Posted July 27, 2015 Author Share Posted July 27, 2015 Hopefully it'll be ok for what I need it for. Paintwork is pretty spotless but just want to give it that bit extra with the clay etc. Quote Link to comment Share on other sites More sharing options...
Sy1441 Posted July 28, 2015 Share Posted July 28, 2015 Tardis then Iron-X will yield far better results. Quote Link to comment Share on other sites More sharing options...
