KUGT4 Posted July 27, 2015 Share Posted July 27, 2015 ...overinflated? - nope, been running @ 32psi on this set since new due to same wear pattern with last set anyone with same issue? - running continental contisport contact 3 Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 27, 2015 Share Posted July 27, 2015 Try using a different pressure gauge, and/or run them at a lower PSI. Excessive wear over the centres can only be caused by over inflation, or possibly excessive toe but that's unlikely on the rears. Is wear excessive, or is it actually fairly even across the centre 3/4? Most people suffer with wear on the outside edges due to running aggressive camber, so you might find yours are actually wearing quite nicely. 1 Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted July 27, 2015 Author Share Posted July 27, 2015 cheers, its not excessive but is causing premature wear as both sides have lot of tread when the centre has gone got to be the tyre gauge - digital but suppose they still fail over time Quote Link to comment Share on other sites More sharing options...
Darren-B Posted July 27, 2015 Share Posted July 27, 2015 Try cornering a little quicker to get the most out of your tyres 1 Quote Link to comment Share on other sites More sharing options...
350zroadsterGT Posted July 27, 2015 Share Posted July 27, 2015 Friend of mine went to a fast fit place and they put the wider rear tyres on the narrower front rims and visa versa, ha said the car drove s#it until it was noticed and swapped back. I remember being told that if you put on a tyre that is too wide for the wheel it will pull the sides in and bows out the centre of the tread pattern? Have you checked the wheel and tyre combinations? Quote Link to comment Share on other sites More sharing options...
kernow zed Posted July 27, 2015 Share Posted July 27, 2015 I had exactly this problem with rainsport 3 on the rears. Completely flat evenly over the middle with loads of tread at the edges. Have now put on nokian zline and dropped the pressure from 35 to 30ish psi so hope i will get more than 6k out of them. Will probably stop doing screechy wheel spin starts too 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 28, 2015 Share Posted July 28, 2015 Excessive wear to the centre section is over inflation where as wear to the edges if even is under inflation, however if the wear is to one edge only especially on fronts, is tracking or hard cornering. Quote Link to comment Share on other sites More sharing options...
