Twi6453 Posted July 26, 2015 Share Posted July 26, 2015 Can anyone help went to silverstone yesterday and got stuck in a queue for over an hour (my 350 has had a brand new clutch and flywheel fitted 2 months ago ) my clutch started to stick then nearer the end it got even worse where I had to force her in to gear now could this be a engine cooling problem or the clutch itself? It runs fine any other time any help will be appreciated Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 26, 2015 Share Posted July 26, 2015 If it is a DE that you have then a fluid change, braided line and slave cyl should fix your issue permanently. Quote Link to comment Share on other sites More sharing options...
Twi6453 Posted July 26, 2015 Author Share Posted July 26, 2015 I've had a new slave cylinder in as well not sure if he did fluid change and braid line will check paperwork and ask the mechanic. Also would it be worth upgrading the fan to a mishimoto twin fan? Cheers for the help Quote Link to comment Share on other sites More sharing options...
Sargara Posted July 27, 2015 Share Posted July 27, 2015 I've had a new slave cylinder in as well not sure if he did fluid change and braid line will check paperwork and ask the mechanic. Also would it be worth upgrading the fan to a mishimoto twin fan? Cheers for the help The fans wont affect your clutch so id save your money for now. If the slave cylinder has been changed then make sure the other 2 bits that Zmanalex mentioned have as well. Quote Link to comment Share on other sites More sharing options...
Twi6453 Posted July 28, 2015 Author Share Posted July 28, 2015 Thanks guys Quote Link to comment Share on other sites More sharing options...
GriffGTV Posted July 28, 2015 Share Posted July 28, 2015 ...following that, it could well be a defective new cover plate or sticking release bearing? - hopefully bearing was changed with clutch kit so both warranty covered - release arm + bearing re-assembled incorrectly? Quote Link to comment Share on other sites More sharing options...
Twi6453 Posted July 28, 2015 Author Share Posted July 28, 2015 To be honest the guy I've used both the mechanics he employs are 350z boys as well so they should know there stuff apparently but the haven't done a clutch fluid change Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 28, 2015 Share Posted July 28, 2015 Master cylinder also a very strong possibility. Quote Link to comment Share on other sites More sharing options...
GriffGTV Posted July 28, 2015 Share Posted July 28, 2015 hope the master is more accessible than on the GTV... Quote Link to comment Share on other sites More sharing options...
