Chris Wiltshire Posted July 23, 2015 Share Posted July 23, 2015 Hi, I'm going to be looking at buying a set of 19" Varrstoen ES2 although I would prefer TE37's.. What offset and widths would you recommend for best fitment with brembos? I would love to have a bit of dish going on and for the rears to be wider. Along with this what tyre sizes work best? I'm not lowered but at the moment I run 18" Rays with 20/25mm spacers which sit pretty good, however I have noticed lately that I have marks in the outside tyre tread from the arches! So obviously if I go 19" its going to be worse? Would it be a case of my shocks being worn or not taking corners like schumacher with the 19" on? Would 9.5 +12 front and 10.5 +12 work? Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 23, 2015 Share Posted July 23, 2015 They will fit for sure, just loose the spacers might need to roll rear arches depends on ride height. give chris a email over at http://www.tarmacsportz.co.uk/contact-us.aspx as he is one of varrestons biggest distributors in Europe and will be able to confirm if they will clear your brakes ok 1 Quote Link to comment Share on other sites More sharing options...
350zedd Posted July 23, 2015 Share Posted July 23, 2015 (edited) Zedd has a set of ES2's and I've just bought some ES1's. Both sets are 19x10.5 rear and 19x9.5 front. Offset ET12 The ES2's just clear the Brembos at the front. No spacers required. You will need to roll the rear lip though to prevent rubbing, but they look great and fill the arches. Tyres: 245x35x19 on the front and 275x35x19 on the rear. Edit: They will rub slightly on the backs at standard height so need a roll Edited July 23, 2015 by 350zedd 1 Quote Link to comment Share on other sites More sharing options...
