Matthews5 Posted July 21, 2015 Share Posted July 21, 2015 First post on here! I've just put my zed on WedsSports SA60M, Rear 10j 275/35 Front 9j 245/35 Question is I don't think there thick enough, should I have gone for the 275/40 and 245/40? There's so much room in the arches the gap at the bottom looks massive to me, between the skirts and the wheel, and on the other side, the wheel to the bottom of bumper? What do you think? Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 21, 2015 Share Posted July 21, 2015 You don't change arch gap with tyres, you do it with lowering springs. Quote Link to comment Share on other sites More sharing options...
Mikevv Posted July 21, 2015 Share Posted July 21, 2015 I'm assuming 19 inch? Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 21, 2015 Share Posted July 21, 2015 You don't change arch gap with tyres, you do it with lowering springs. Dunno I went from a 265/40/18 to a 275/45/18 and it appears to have closed the gap Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted July 21, 2015 Share Posted July 21, 2015 I use higher profile tyres to close gap. Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 21, 2015 Share Posted July 21, 2015 Pics please. Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 22, 2015 Share Posted July 22, 2015 I use higher profile tyres to close gap. You shouldn't, as that's how the TCS starts getting confused. You also end up raising the car, which makes it look like a 4x4. That said, you will get a more supple ride as there's more give in the tyres. Normally you'd do that by dropping wheel sizes instead though. Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 22, 2015 Share Posted July 22, 2015 You don't change arch gap with tyres, you do it with lowering springs. Dunno I went from a 265/40/18 to a 275/45/18 and it appears to have closed the gap Quite. It'll work, but it's the wrong way to do it. You increased the profile by nearly 20mm, or 3/4". Why did you do that, out of interest? Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 22, 2015 Share Posted July 22, 2015 You don't change arch gap with tyres, you do it with lowering springs. Dunno I went from a 265/40/18 to a 275/45/18 and it appears to have closed the gap Quite. It'll work, but it's the wrong way to do it. You increased the profile by nearly 20mm, or 3/4". Why did you do that, out of interest? mistyped meant 275/40/18 Quote Link to comment Share on other sites More sharing options...
Bockaaarck Posted July 22, 2015 Share Posted July 22, 2015 First post on here! I've just put my zed on WedsSports SA60M, Rear 10j 275/35 Front 9j 245/35 Question is I don't think there thick enough, should I have gone for the 275/40 and 245/40? There's so much room in the arches the gap at the bottom looks massive to me, between the skirts and the wheel, and on the other side, the wheel to the bottom of bumper? What do you think? If you're running 192 rims those tyre sizes are fine. I run exactly the same 245/35 + 275/35, I can't say I have noticed the gap between the tyres and the arches being particularly huge. Check my sig to see how my Zed looks on the same sizes you're running Quote Link to comment Share on other sites More sharing options...
Matthews5 Posted July 22, 2015 Author Share Posted July 22, 2015 They are 18" btw guys, I'll post some pics once it's lowered! Quote Link to comment Share on other sites More sharing options...
brillomaster Posted July 22, 2015 Share Posted July 22, 2015 ah that explains a lot... yeah, you should have gone for a 40 profile in those widths on 18" wheels. general rules, when going up a wheel diameter (18" to 19"), and keeping the same width tyre, drop one size in profile. when going for wider tyres (225/245 to 245/275, but keeping the same wheel diameter, drop one size in profile. when going up a wheel diameter and getting wider tyres, drop 2 sizes in profile. Quote Link to comment Share on other sites More sharing options...
