*** TORQEN DEAL ALERT *** 350z DE Motordyne plenum spacers - IN STOCK
Adrian@TORQEN
1. 350z DE Motordyne Engineering 5/16" Basic Plenum Spacer
This is the 5/16 Stealth Plenum Spacer Upgrade for the 03-06 350Z. Gains from 11-13HP, simple and easy install. Works with OEM Strut Bar and Engine Cover.
2. 350z DE Motordyne Engineering 5/16" Iso Thermal Plenum Spacer
This is the 5/16 Stealth Plenum Spacer Upgrade for the 03-06 350Z. Gains from 12-14HP, simple and easy install. Works with OEM Strut Bar and Engine Cover. Iso Thermal Spacer Reduces Heak Soak and helps prevent power loss. Iso Thermal Gasket also allows upper and lower plenum to run cooler.
3. 350z DE Motordyne Engineering 5/16" Copper Iso Thermal Plenum Spacer
This is the 5/16 Stealth Plenum Spacer Upgrade for the 03-06 350Z. Gains from 12-14HP, simple and easy install. Works with OEM Strut Bar and Engine Cover. Iso Thermal Spacer Reduces Heak Soak and helps prevent power loss. Iso Thermal Gasket also allows upper and lower plenum to run cooler. Copper Throttle Upgrade Recommended for areas that have Heavy Snow Fall or Salt on roads.
Edited by Adrian@TORQEN
hey do you have these in stock and do they come with instructions?
and roughly how long would long say they take to fit ?
The one with the copper spacer took me around an hour or so to fit, so a standard spacer your looking 45 mins to 1 hour. They include detailed instructions :)
  • 4 weeks later...
  • 1 month later...
  • 5 months later...
  • 1 month later...
