geg1992 Posted July 19, 2015 Share Posted July 19, 2015 Put a deposit down and should be picking up a 55 350z on Wednesday. I've read horror stories about rust and this is my main concern. I inspected the usual places and there were no signs of rust at all. However, at the very top of the suspension where it connects to the body, there was surface rust there. I was told not to worry about this by my mechanic friend. I plan on owning the car for 2 years then selling it to help fund my deposit so I really can't afford for rust to be an issue! I know you can under seal then, where can I get this done and how often does t need to be re done? I think it's been done already. Thanks! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 19, 2015 Share Posted July 19, 2015 Rust is usually only an issue if you are in a salt water atmosphere, so location is key. That is why you find all the jap imports are totally rust free. If you are concerned about certain areas on the car, then just scrub down with a wire brush and apply some body shutz by brush or aerosol. 1 Quote Link to comment Share on other sites More sharing options...
Juggalo Posted July 19, 2015 Share Posted July 19, 2015 (edited) My cars 2006 and there isn't any rust anywhere that I can find. I'm sure there's surface rust under the car somwhere, all cars get it. One place I notice is vulnerable is the rear arches. they have a lip on the arch which nicely collects crud. So make sure you clean that out with a hose and your fingers. Should be good. Surprised they didn't put a liner in those arches really. Edited July 19, 2015 by Juggalo 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted July 19, 2015 Share Posted July 19, 2015 (edited) As agreed with zmanalex and juggalo :thumbs: Best of luck with the new car buddy, hope the weather stays fine for you. Edited July 19, 2015 by veilside z Quote Link to comment Share on other sites More sharing options...
KyleR Posted July 19, 2015 Share Posted July 19, 2015 Rear arches just behind the wheels close to the rear bumper is the common spot. Quote Link to comment Share on other sites More sharing options...
geg1992 Posted July 19, 2015 Author Share Posted July 19, 2015 Great, thanks for all the replies! I asked about the bottom in terms of rest and got a reply of "not a lot". I assume all cars will have a bit though! I worry about it getting worse though. Quote Link to comment Share on other sites More sharing options...
allaboutthepasty Posted July 19, 2015 Share Posted July 19, 2015 It's only usually surface bubbling etc that is easy enough to get rid of. I've not really heard of anything terminal on a Zed yet? Rear arch is common one as people have said. Mine needs doing. Quote Link to comment Share on other sites More sharing options...
geg1992 Posted July 19, 2015 Author Share Posted July 19, 2015 Thanks! Also what about the suspension rust where it connects to the body of the car under the rear arches? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 19, 2015 Share Posted July 19, 2015 Thanks! Also what about the suspension rust where it connects to the body of the car under the rear arches? Suspension turrets should never give you any structural rust issues. Quote Link to comment Share on other sites More sharing options...
geg1992 Posted July 19, 2015 Author Share Posted July 19, 2015 In terms of any rust is not to worry about? Quote Link to comment Share on other sites More sharing options...
