Trigs drift car project (350 power)
Trig
Right guys I've been on the fourm for about a year when I first came up with the idea but I've only just got round to starting it (other projects/family stuff).
Before I go to far I know a lot of you won't even be interested in this but I'm posting on here as I know I will need some advise on running tuning the engine once it's in the shell.
I was planning on trying to run on the standard ECU but as time has gone on I think I would prefer a aftermarket ECU loom for ease on fit and so I know I can upgrade engine later and get remapped as when needed.
Anyway if you've got this far about time I told you all the plan!
Ready??? As I'm a ford nut as hart this is loosely based on a Mk1 Escort Estate.
I say loosely as it's only the outer shell that will be used.
The plan is to build a custom chassis fit engine box axle drop skin over fabricate rollcage/semi space frame to hold components and fix skin to chassis. Easy really lol.
O one last thing is I have till the 31st may to get it done!!! Fingers crossed.
Now if you still reading I bet you would like to see how I'm getting on???
Well ta da here he is (so far) . . . . . . . . .
671cd098297768fa58e1e72d03cb3997.jpg0e57292428f3b941616e093e9c3ce488.jpgf223e2e7f2889d9c9f06838cfb7253a6.jpge121cc6a7ff8e0de4534237f461233ed.jpg
Sent from my iPad using Tapatalk
Awesome! I work at Tarnock Ford (not very far from you) and we'd love to see it here.
This is our Mk1 Transit with a 2006 Transit internals, interior etc. Body was slightly elongated to fit it and it is a hand painted livery! The Escort is sold now, but was a 0 miles rally car we built for historic rallying as an RS2000. One of many projects we've had/have!
10489698_693395367363314_6486774375288863570_n.jpg?oh=ba458cb9abac8d5f4170ab5fc047d2e5&oe=55570BC3&__gda__=1431474601_e307d114b7bc5c60baa40ca595f51228
  • Like 3
Most likely to have seen me or the car at castle combe doing drift demos.
I also hold privet track days there few times a year. Got one coming up soon if anybody's interested?
My blue mk1 I still have in bits in the garage was running a 1800 zetec.
The mk2 was running 2.3 Duratec built by mountune 280hp on a 6speed sequentail Quaife gearbox.
Pretty sure I've seen your car at Combe before too. :dry:B)
I want to do some track days this year in my Zed and Castle Combe is my favourite circuit so yes I'm interested depending on dates/costs etc. ;)
PM me if you like to let me know any info you can about it & I'm sure others might be interested too. :thumbs:
Stock Zed engine loom and throttle pedal needed together with stock ECU. Extend throttle pedal wires from ECU to pedal few wires and relay needed to make the motor run. We can remove NATS from the ECU so no need to have to bid the stock key and key reader box/loom.
Have you brought a motor yet?
I'll pm you with details of the track day mate next one is 20th March and nearly full.
Mark that's great lots of people have said I would need the peddle and dash.
Good to get some proper info. ;)
I have bought the engine box and test driven before too.
I have the engine loom and ECU but that's it no dash pats or peddle as the guy I bought it from was fitting V8. ;)
Don't think I can PM as I'm new or not posted much.
My Combe days are £150 per car open pit contact me on trig.bishop @ aol . Com
To "PM" (private message) someone just hover your cursor arrow over their user name and you will see the "send message" icon pop up. Click on it and write your message.
You can do it from day one with zero posts so you shouldn't be having a problem with it. I'll send you a message anyway first. :thumbs:
Got it now cheers G think it was cuz I was on tapatalk couldn't work out how to do it easy now I'm on the normal web page.
And here's a little Friday night update.
Not much done this week as working lates and cold nights. :( Hopefully more tomorrow and next week when I'm home at sensible time.
859e7fa9b3b40e67f7f85f8809387554.jpg47f491b866d100f743b2ff014b17521b.jpg4c29c216be167cd97dde24b7462780fa.jpg
That's one rail done with light weight holes and the crash point in place just the other side to do then I can put the chassis back in place on the jig and start to work out where how body will sit then the engine box can be tried in for the first time. ;) keep your fingers crossed.
Small mile stone.
Chassis is 99% done just some closing plates and wedges to go in at later date.
All set back up in the jig to make 100% true well it's within 1mm. Tacked up ready for next stage. ;)
